How much?
Oracle
Feb 8, 2009
155
I'm just curious.... :coat
Local job, consists of three parts:
1. Replace an existing faulty 2 gang dimmer
2. Install a new double socket on the same stud wall as an existing double (so basically up the stud wall, 8 feet along in the loft and drop down. socket to be sunk - drylined box. Only issue might be noggins!
3. Install new aerial socket next to new double socket - easy access in the loft to existing aerial cable that can be "tapped" into - dryline box sunk in - again only issue might be noggins!
New house (about 7 years old, all bonding, earth and RCD ok)
How long and how much (inc materials)? ?:|
O.
Evenin'
I was thinking 3 - 4 hours...especially if I have to cut holes and make good to deal with the noggins! (where's my hole saw) :D
I reckoned on 140 quid inc materials.
O.
Same as others i would be looking to say 140 / 150 based on going well.
I'm just curious.... :coat Local job, consists of three parts:
Allow 10mins + cost of dimmer.
Allow
1/2 hour for cut dry-line back box, terminate cables, identify circuit safe isolate etc..
1 hour up the wall
1 hour down the wall
15mins across loft & any clipping
so 2.75 hours + materials
Allow
1/2 hour fixing back box and terminating ends, joining to existing feed.
1 hour up wall
15mins for any clipping or any other tricky bits
so 1.75 hours + materials
O.
I normally think these jobs though in a mental stage by stage approach..
highlight in blue above...
so total guesstimate time would be..
10mins + 2.75hours + 1.75 hours
then round up to the next full hour..
5 hours minimum (or 1/2 day) @ whatever your labour rate are +
materials +
