twist joint for repair?
reminds me of a job about 18 month ago. new build house, they had just moved in. had to drill a hole to outside for cable for outside light. gas meter meter directly below where i wanted hole on other side. gas pipe goes thru back and appears to go into boxing on the other side (in the house). so i drill hole at opposite side to boxing - about 750mm to the side and 300mm higher than where gas pipe leaves meter boxThe closest one I can remember of hand was doing a kitchen rewire chiselling out wall below worksurface and luckily spotted a copper pipe plastered in wallbefore I cut through it and it was gas.
Batty
dont want something to go wrong with that vehicle!Nope.............. replaced the damaged cables in their entirety, cant have any potential problems for the future when the vehicle is in use.
Frightning stuff gas did you see the programme about what happens when properties go up.reminds me of a job about 18 month ago. new build house, they had just moved in. had to drill a hole to outside for cable for outside light. gas meter meter directly below where i wanted hole on other side. gas pipe goes thru back and appears to go into boxing on the other side (in the house). so i drill hole at opposite side to boxing - about 750mm to the side and 300mm higher than where gas pipe leaves meter boxdrill got about 40mm into wall, i stop and think 'that doesnt sound good' and quickly run outside to turn gas off...
what programme was that?Frightning stuff gas did you see the programme about what happens when properties go up.Batty
That's ok - it when you need a bit of extra light in the dark corner and strike a matchwhat programme was that?gas isnt that bad... unless there is a 12mm drill bit thru the pipe!
Not sure what it was called had different disasters. Leaving a bath running, what happens if a house catches on fire and how quick it spreads, the gas one, Patch drilling through a wall was on there. Frightning stuff gas leak was the worst one though.what programme was that?gas isnt that bad... unless there is a 12mm drill bit thru the pipe!
maybe it would have been better hitting the gas pipe - at least the gas wont flood your house, and can normally be turned off a lot quicker than waterCould have been worse, the gas pipe was an inch to the right of it.
