How to limit power draw.
almendro
Aug 29, 2024
2
Spain
I have an axpert max 2 off grid inverter.
It allows charging from an AC source. Max 60 Amps AC input
I have a back up solar system which uses a victron inverter with max 2000 watt output.
If I attach a generator to the AC input it works fine.
If I attach the victron inverter to the AC input it lasts 3 seconds before shutting down.
The axpert max is trying to take in too much electricity and it is too much for the 200 watt victron inverter.
Is there some sort of device I can put between the two inverters to stop it drawing too much current.
In the config of the axpert max there seems to be no configuration which would limit the AC input.
Any ideas?
