- Nov 28, 2009
- 14,821
- 996
Went to look at a job today, original call was "can you give me a quote for a new CU"
When I got there, it seemed the "problem" was he had solar PV fitted 10 days ago, and there were no spare ways on the existing CU.
Now in that situation, I would expect a competent electrician to henley off to a separate mini CU for the PV, particularly as the existing CU had no RCD.
No, instead, he disconnects the immersion heater, and connects the PV inverter there. Then says "you'll need an electrician to re connect the immersion heater."
Still it's a couple of days work for me, new CU, fit missing water earth bonding, and a few other minor alterations.
There was me thinking with MCS etc, all the sparkies doing this were well trained and did things properly.
