Robin Spark
- Joined
- Aug 30, 2009
- Messages
- 1,425
- Reaction score
- 0
Can you apply diversity rule to induction hob when calculating CPD and cable size?
Just been doing some research on internet and there was a post on here saying that you cant due to the boost function on these appliances.
BTW I was just asked for advice as friend is changing his hob and having some other non electrical work done by kitchen fitters who have said the original 6mm cable needs to replaced with 10mm, so just needed to confirm before giving him any conflicting advice.
For your info:
The consumer unit is on opposite side of kitchen wall, and cable run is only about 6 metres in total clipped direct and then buried in plaster on kitchen side.
For your info:
