ericmark
I have seen a few comments by HSE that we are going OTT with PAT testing and 12 months tickets on all items and testing new items is not required.
Considering we are only really interested in safety I do sometimes wonder why we do so many tests? Does it really matter if it draws 1kW, 2kW or 3kW?
Where I started really to think about what really needed testing was with a cooker. Now to get access to connections on cooker means pulling it out. On the isolator means finding where it is supplied from to isolate elsewhere as the HSE says we must do. This means in real terms we often ignore them not testing them at all. Clearly this is not what we should do.
However if we only checked the earth bond with no other checks at all then it's extremely unlikely there would be any fault which could cause injury.
So question is where there is no plug on the end of an appliance would visible an earth bond only test satisfy the HSE as to ensuring the appliance would present no danger to the user?
Eric
Eric
