brummydave
that's mighty kind sir. bare bones as in no mcbs or no rcds either?Im fairly sure I have a couple of metal bare bones wylex units kicking around if you want to make a forum donation for one.
One problem with the nice big joint box - is the big hole in the front. one reason it's being changed!With the recent relevations that c/units do not have to be fire proof i will be fitting more metal clad ones. Last one i did in a situation like this was to remove the guts of the old board and mount the new one over the top, thus leaving all the conduits in situ and a nice big joint box if any cables are too short.
thank you. sounds like a top quick fix... although it'd still be better to fit some sort of RCD protection! So will suggest a planned more leisurely replacement.If you're desperate I changed one of these wylex boards last week, I'm sure the screw on cover is still bouncing around my van at the moment. Let me know if you want it.
In a word, No.Dave,i do hope you are not seriously contemplating that!?
Is that an NIC pir? The visual type or drive by??I always do a limited PIR before a board change, after a while you will find it wins you more work than it costs you.
im guessing you havent done much fault finding then. low IR is very common. often so low, its better to switch to continuity instead of IRNow I know it's above the 1MOhm minimum, but i've never seen an actual reading this low! Was thinking to repeat the test but circuit by circuit this time.
In the grand scheme of things, not really. I've mostly installed. The faults I have found have been things like nail through cable, loose terminations.im guessing you havent done much fault finding then. low IR is very common. often so low, its better to switch to continuity instead of IR
I was getting readings over 2Ohms at most lighting points.... But as I read table B6 in the OSG, I could go up to a 10A MCB with readings up to 3.71Ohm. So a 6A will defo be fine?r1 r2 of 3.1
something badly wrong there for a normal 3bed semi, unless its a [very] big flat,!
you might have to downsize your MCB a bit!
I'm not sure, I'm struggling to find values for resistance of steel conduit so working out what I should be getting is tricky!Its not as simple as just having your readings under the permissible limits Dave,
Are the readings consistent with what the anticipated circuit length is likely to be?
