Hello,
I'm looking to install an electric meter for a shared property with tenants.
At present, the electrics are shared and all going into a single consumer unit.
We are looking to do the following, but as unsure whether it would be the ideal way of set up.
1. Install Henley blocks after the breaker from the meter
2. Install a small breaker for the tenant side by the existing mains and connect to 10mm2 core cable.
3. Surface run 10mm2 core cable to the tenant side and connect it to an electric meter and then to a new consumer unit
The tenant side will have around 4x ceiling lights, 8 double sockets, 1 electric cooker, 1 electric oven.
Heaters will be movable oil heaters.
Could you advise if the 10mm2 core cable will be sufficient and also what size breaker would be ideal by the Henley block.
Also could anyone advise on a decent pay meter. I can deal with coins or card payments.
I will get a certified sparky to check and sign it off, but I would like to learn to do the leg work myself.
Thank you to all in advance.
