- Oct 22, 2010
- 14,635
- 1,189
I would have hope that the OP had sorted this by now as they asked the question almost 3 years ago
just saying
just saying
It is vital that you ask your expert HVAC tech to make the programmable thermostat works just as well with both the heat and air units as there are some that work better with AC units than they do with heat pumps causing problems during winter. On the other hand, temperature settings and thermostats only make up a part of the picture as far as heating and cooling a home or business efficiently. You should also think about weather stripping your home to keep cool air from escaping in the summer and warm air from escaping in the winter.
The skilled specialists will be able to assist you with the large variety of programmable thermostats with improving the efficiency of your HIVE system. Furthermost homeowners set their thermostat to one temperature and certainly not change it. When you install a Smart Thermostat, you can set your temperature at dissimilar times during the day and the thermostat programs itself to learn your temperature preferences. This saves you time as you don't have to concern about altering the heat ever again.
It has been an 'intermission break' since day one as far as I can see...Will the movie start after the adverts ?
