Installing windows help
Andy™
©Resident Geordie™
Jan 1, 2009
30,704
1,414
S. Tyneside
i have a computer that i want to install XP SP3 onto. the hard drive previously had some version of linux IIRC (i installed it to see what it was like, but never got any further).
i now cant get it to start. it goes so far through startup then says
GRUB loading
GRUB loading, please wait...
Error 17
cant get it to do anything else from there.
i have changed CD drive to boot first, but it seems to skip past this
Any ideas how to get it to start installing?
there is nothing on the hard drive i need to keep, so it can be formatted/whatever needs done
i have a computer that i want to install XP SP3 onto. the hard drive previously had some version of linux IIRC (i installed it to see what it was like, but never got any further).i now cant get it to start. it goes so far through startup then says
GRUB loading
Error 17
GRUB is the Linux loader, you could have got past this by ensuring that your BIOS was set to boot from CD/DVD first, and pressing the space bar at boot up to go into the MS XP loader
it was set to start from CD before HDD. but for some reason, it wouldnt do that. i have found a larger drive what i have decided to use instead. just waiting for that to format now (it takes a long time!). may go back to that drive if i need another computer for somewhere
Possibly your POST is in fast mode, so you'd probably needed to hold down space bar as soon as the first pre-POST text appeared
Yes Patch that is French!! ;)
When your new drive is up and running, slave your old one to it and format from within windows.
Easiest way to sort.
P.m. me if you need further assistance.
When your new drive is up and running, slave your old one to it and format from within windows.Easiest way to sort.
thats what i was planning. now just need to go to computer shop and get another SATA lead for it
