Hello
Background:
When using optimizers, there is an inverter and the PV are connected in series on the string(s). The optimizers are installed on the panels that need them.
When using Micro Inverter, each panel has one and there is no need for an inverter. The concept of series or parallel is irrelevant as the output of each panel is 240V 50Hz (please correct me if I am wrong)
Questions:
1) Can we add new panels anytime, anywhere when using micro inverter?
My understanding is that with Inverters, the panels are linked in series on the same string. it can be very difficult to add new panels on that same inverter.
2) Is it easier to mix panels with micro-inverter than with a string inverter?
A string inverter has a max and min voltage for the string. When mixing panels of different dimensions one must ensure that the sum DC max and DC min for each panel does not exist the inverter string. I understand that when using micro inverter. This is irrelevant because each panel (or a group of panels) will have its own inverter (micro). Is that correct? PS: The reason for mixing panels of different dimensions is to maximize the cover.
Background:
Questions:
