Hello All
I wonder if someone has the time to respond to this. Hoping no one says get an electrician )
21 way rcbo board. One circuit apparently feeds two 2-way led lamps in the garage (next to the CU). Its black neutral wire has just been cut off and left as a "dead end" within the CU. I turn off the rcbo remove both circuit wires. Using a wandering lead from one of the two lamps, I get connectivity between the red wire at the lamp and the red wire removed from the rcbo as expected. However I get zero connectivity between the neutral black wires (after stripping back a little plastic to expose copper). I do get connectivity between the neutral at the lamp and the neutral bar in the CU.
So apart from asking for confirmation that is a borrowed neutral, to find which circuit its getting it from I presume I can isolate each 6 amp circuit in turn and test for continuity from my lamp's neutral wire? The next question is what to do when I find it. Assuming both radials are tiny which they are likely to be (the one in question only has two led lamps on it!) does having two radials entering a single RCBO in itself cause a c1 or c2 within an eicr ?
