Need some advice on the fitting of an FCU and a socket to en existing ring final. Basically I'm aiming to spur an FCU from an existing socket in my lounge. This FCU will be used for a wall mounted fire drawing no more than 6.5 amps.
Whilst I'm at it I thought I may also add a double socket. This is where it gets tricky. Should/Can I spur the new socket from the old one and then spur the FCU from the new socket? I understand that the socket will not be protected by the FCU in this case, but not sure if this constitutes a spur from a spur which I know is a no no.
Alternatively should I spur the FCU from the old socket and then add the new socket AND the fire to the 'load' side of the FCU, thus having the socket and the fire sharing 13 amps?
Any advice would be greatly appreciated.
Many thanks,
Kalibre
Many thanks,
Kalibre
