- Jul 8, 2010
- 373
- 0
The isolation switch question .
Recently changed a fusebaord for a customer just because they wanted rcbos and done some other minor works , now customer is asking me to remove and blank off 3 extractor fan isolation switches that were allready installed (house is going to be a hmo ) , extractor fans are humistat fans ,
Would you be happy to remove them and blank off? Personally I think as they’re there then they should stay , rather than join cables and blank off . House is 3 story , bathroom 1 is on ground floor , fuse board also on ground floor so easy to isolate without isolation switch .
But if a fault on 1st or Second floor then bit harder in the dark .
Plus vent axia state there should be a 3 pole isolation switch so I’m kind of sticking with leaving them based on that.
What’s your thoughts?
The jobs hour and 20 away just to remove these seems a wasted trip to be honest
