Hi all just a quick question if anyone can help. I'm doing a board change for a elecsa assessment I've had an isolator fitted by the supply company to isolate the supply my question is that the CU main switch is also an isolator so because there is 2 isolation points one at the CU and one that the supply company has fitted do I need a label to say that there is more than one isolation switch.
