Job To Quote On
M107
Billy-the-Kid
Feb 18, 2008
5,561
28
Berkshire
Oh boy where do I start....No pictures yet but here is a little insight.
Currently this builders yard has a sp TT supply into one store building old 3036's not an rcd in sight, bog standard sockets & metal back boxes (not metal clad) surface mounted no grommets with T/E clipped down walls.
This cu feeds a second cu in the office that does more pvc surface mounted sockets & internal lighting.
cu 1 also does all the outside lighting.. all the floods are wired in T/E that is hung through conifer hedge around the yard, been there so long the trees have grown around & enclosed the T/E in places.
It also has a 2.5mm submain in T/E, hung through the trees to an old broke down luton van, i here there is a metal clad 3036 cu hanging on a length of bailing twine feeding a couple of sockets & a light.
So I have to quote for new cu's / submains / rewire stores & ofice + new submains to an external cu for flood lighting & 2x submains to another two sheds that require cu's & circuits, another submain to a caravan hook up for shipping container hook up in the future. Sort out all the flood lighting
Need the supply cable extending/replacing from pole for relocation of metering & cu 1...............must remember to call dno in the morning.
Pictures will follow in the future.........................................if my quote is accepted.
Had the old "can you reuse this bit of swa we pulled round"
It's 2 core 6mm underground throught scaffold pipes across the drive way & round part of the yard...IR testing L/armour 0.62 ohms didnt bother testing anymore when he piped up........" we couldnt pull it by hand any more, felt like it was stuck so we tied the end to the jcb bucket & pulled". :slap No mate it's knackered cant reuse it.
