hello
i have the above tester and the manual does clear things up for me. i am new to the testing process and not too sure how i can use all the functions properly. the pscc test is just that, no pefc.
the pscc test is
select range 200 2000 or 20kA
connect the three test probes
red probe to phase, black probe to neutral and green probe to neutral, (this would require attaching the neutral and earth probe together)
ensure that the two green P-E and P-N led s are on( i think this is checking polarity before testing)
press test button
thats it
then it says, "if the psc ranges are selected whilst connected to a socket outlet via the mains lead, a test will take place between phase and earth due to fixed wiring of the moulded mains plug i.e a phase-earth fault current test."
that is all it says, i am not sure how to get the pefc at the board. i am thinking that the neutral and earth probe stay together and test again between phase and earth? i am not sure if this would damage the tester though.
any help/advice would be great
thanks
simon
the pscc test is
press test button
thats it
thanks
simon
