but he's talking about a 3 phase supply, which as I already stated works out at 36 amps per phase. If you were really able to draw 100A per phase continuously, then it would be a 75KVA feed.Unless I am mistaken KVA is just kilovolt-amps, or volts times amps divided by 1000, so 230v x 100amps÷1000 =23KVA without taking power factor into account and that 230volts is your standard incoming supply in the UK
