Hi
Was wondering if any of you kind people could help me out with a question I need to answer for my course.
Question is..
When carrying out an insulation resistance test between live conductors of the socket outlets a short circuit is discovered.
a) Define the term short circuit Done this one
B) describe with the aid of a labeled diagram how you would perform a test to determine the location of the fault within the damaged cable. Not sure how to do/draw this ?
c) Describe the action to be taken to rectify this fault.
Check and replace damaged cable or socket ????
Was told this answer by a spark I have been helping out, but he did say that he was not sure if that's the answer needed but " would be his answer"
Many thanks,
Lyngarth
Question is..
Many thanks,
Lyngarth
