sellers
- Feb 2, 2009
- 2,583
- -2
Hi folks,
I've just bought a wake up light off ebay, Philips hf3461.
For those who don't know these lights start to warm up 30mins before you set your alarm then to full brightness by the time you want to get up. Hopefully waking you up gradually. Anyway it turns out its a very fussy machine.
The seller explained the original lamp was dead, so they have put another one in. It turns out that the original recommended light is discontinued, and this lamp he has put in has put in stays on constantly and does not dim or switch off at all.
The recommeded lamp is this
http://download.p4c.philips.com/l4b/9/922800544224_eu/922800544224_eu_pss_aen.pdf (which is discontinued)
Philips recommend this as a newer alternative
http://www.dutchwest.co.uk/Philips-EcoClassic-Dimmable-Clear-Halogen/dp/B004QDNFWC
which is what I have, albeit not a phillips. but this doesn't work. Many others have found this out too.
The seller is being quite unhelpful, so before I set up a dispute, I'm wondering if anyone can tell me what the first light is, surely there must be other brands still making this lamp? I'm thinking along the lines of a sodium discharge lamp, possible a white SON-E 100w.
Does anyone know if a son lamp can be dimmed in anyway?
