This is my first official post so please excuse if I make a mistake I am wondering if there are any tips or advice for when you are testing . Say I was doing a test after changing an emergency light in a corridor of a care home, when doing the tests such as continuity or insulation resistance where it states test at every point or disconnect luminaires etc what is the way to do this when there are 15 emergency lights spread across a large building I’m not sure if you should go round and disconnect every light on the circuit or if you should test at each point this seems like a potential for problems as your altering things that your not scheduled to work on any tips or advice would be greatly appreciated
