TonyCE
- Joined
- Jan 14, 2010
- Messages
- 45
- Reaction score
- 0
Had a call from the lodgers last week - There is water dripping from the combi boiler (which is a wall mounted Vailiant ECotec jobbie). Boiler still working though.
Went round to inspect and sure enough when the boiler fired up (with the casing removed) there was water dripping out of the inspection hatch of the combustion chamber.
Phoned up my plumber who wearily explained that he had had ten of these calls that day - and to go outside and check the condensate outlet which was likely frozen.
This was indeed the problem, frozen up outlet causing the condensate to back up into the boiler. Fortunately it was resolved before the boiler was ruined by water dripping into the electrics.
Removed the blockage, and temporarily venting to fresh air.
Might be happening somewhere near you guys so hope this is of some use.
Tony
Tony
