Hi there can any one help ? I want to fix a led. into the charging circuit of my battery operated screw driver. The charging system is only 3.5 V. I want the led display so that I can see if the charger is working at a glance. Should the led be wired in series or parallel and what rating should the led be it
is a red led. Some say that a resitor should be fitted in the line, is this correct. I can be contacted
directly by e-mail [email protected]
thanks,
mike.
thanks,
mike.
