Thanks for tidying up! appreciate it..Yes i laid the SWA cable, connected to junction box fitted on wall at the bottom of the garden. IP56. I carried out continuity test and IR test using a digital multimeter which gave clear readings at the time.
Hello ColinGuinness
I am confused here:|
What exactly do you call a clear reading???
What is a "Clear" continuity reading when its at home....
Do you mean your resistance R1+R2 is the correct value appropriate to the length of the cable run?
and what are you calling a clear Insulation Resistance test reading?
Do you mean in excess of 999Megohms or just above the min acceptable 2Megohms??
remembering that for new cables an acceptable value would NOT be the min 2meg value?
Thanks for the info on the multimeter. I'm off to buy one for the weekend!
to buy a multimeter?
thought you said you had a test meter?
What about an insulation resistance tester you will need a few hundred to get anything decent!
Could I please ask are you an electrician or just training / DIY
It does sound as though you haven't actually done the basic tests for this cable prior to sticking the lectwickery on to it! :_|
How are you proceeding with getting the building regs compliance certificate?
Are you able to self certify?
Then the other question has to be..
Has the RCD been tested?
what are its trip times & current?
