- Jun 21, 2008
- 17,023
- 47
Guys,
Looking at changing some 4 pin compact fluorescent lights in a room that will be a staff room. Floating ceiling to come down and false ceiling going in with solid board insulation, then plasterboard and skim.
Thinking a couple of LED 'fluorescent' strip lights. There is a second circuit that was wall lights. I was thinking of re-using this and dropping 2 230V LED downlighters above two desks.
My questions:
My questions:
- Never fitted a downlighter. Is it a case of a suitably sized hole and wire in series 230V L&N? How much space is required around the insulation?
- If installing above a false ceiling what are the rules regarding cable support? Currently all wiring draped over the floating ceiling with no support.
- Is there a clever way of working out lighting requirements in lumens using volume of the room and fittings outputs?
