Light switches
Dmoblay
Nov 8, 2016
2
Cheltenham
Hi, I have installed a new light switch. Including running a new t&e from the junction box in the ceiling (as there was previously no earth running to the switch).
I've tested voltage across live & earth terminals at the switch and getting a 240v reading.
The switch is a toggle (made of metal) however and (for no other reason than my paranoia) I want to confirm the toggle is not live through some kind of (high unlikely) fault or random act of whatever!!
As I say I've tested voltage across live and neutral. I've held a non-contact voltage detector pen up against the plate as well and in certain spots I get the audible beep. But I get this on my plug sockets too which are plastic and so think it is just picking up the live terminal behind.
Is there any other check I can do before touching the toggle to double check I'm not about to get a shock???
So just touch proves to the switch toggle/metal plate and to the earth? And I guess no reading means good!?!?
Yes, they should be at the same potential so a reading somewhere near to 0v would be good
