Hi
I am currently only several months into my Level 2 so i am not very experienced.
I have a bar that consists of spotlights that has had to be taken down from the kitchen as it was about to fall off ( dodgy Plastering )
I want to put a battern holder up there but the cables are just not long enough to terminate into the holder.
So ideally i am going to need to extend the cable cant replace as it is not possible to locate cable back to the supply.
How do i extend the cable I was thinking of using a 5 amp strip connector and running a small amount of 1.0mm twin and earth But is a strip connector the right item for the job.
Do i need a junction box if so which one?
Any help would be great .
