paul b b
evening all,
how many lights or wattage do you allow per sq foot?
thanks
thanks
Depends on where, when and why, and also with other factors thrown in, like available natural light etc... Far too vague a question, there is no fixed watts per foot that applies to everything.how many lights or wattage do you allow per sq foot?
is there not a genral guide line.Depends on where, when and why, and also with other factors thrown in, like available natural light etc... Far too vague a question, there is no fixed watts per foot that applies to everything.
Not really. Differnet types of light do different things so a 100W GLS is not the same as 100W of downlighters.is there not a genral guide line.
It would depend on the room and what it is to be used for, and what else is in it, so like a gloss white kitchen with white walls, floors and ceiling would probably need less light than a dark oak country kitchen with dark red walls and quarry tiled floor.how many down lighters would you put in a room 4m x 4.5m
and its usualy easy to add another one in the centre later if need be4 should be enough.
To add to Lurches comment about all the variables that would be in the mix...thanks lurch, i understand that, but was hoping that there was rule of thumb, like 2watta per sqfoot or something. oh well back to guesing lol.thanks anyway
reluxFor the commercial lighting plans there's a decent program I have used to do some decent lighting plans and designs. Can;t actually remember what it's called though, fairly certain it was free. Dialux I think it was, job for this afternoon, download and reinstall that.
For kitchens I tend to end up with 3 rows, or sometimes 2. The outside 2 I put around 600mm from the outside edge so the light falls on the worktop from above rather than from behind creating shadows, and then a\some row(s) in the centre to fill space if required, possibly offsetting them from the main lighting so if there's say 6 up the edge maybe put just 4 or 5 in the middle.Regarding the downlights , I'd put 6 x 50w G10s in Paul bb,s room. 3 in each row, with one on the centre line then 1mtr apart.
I'd agree with Ev. As a "rule of thumb" I generally start with a 1m grid and put a light on each corner.Regarding the downlights , I'd put 6 x 50w G10s in Paul bb,s room. 3 in each row, with one on the centre line then 1mtr apart. Deke
take a lot of getting used to! i can do basic designs with it, but thats itI have used relux a number of times in commercial, works well and looks professional when printed out. Takes a bit of getting used to but is free with good support from manufacturers.
