Hi all
Just had the boiler 'engineer' out to fix a fault on my combi boiler and he's gone away scratching his head saying call the manufacturer out to get it fixed as he hasn't got a clue.
The fault is this....when central heating is switched on the boiler continues to fire and heat the system until the radiators are red hot to the touch. DHW works fine and the gas valve modulates so that the required temperature is held. There are no external controls such as room stats. I have replaced the PCB twice and replaced the thermistor twice. All cables and connectors are securely fitted and in good condition. All micro switches are operating correctly as is the diverter valve.
It seems the radiators just keep calling for heat and ignore the thermistor while the hot water switches off when desired temp is reached. All mechanical components are working fine.
Any idea as to what is happening would be very much appreciated before I call out Baxi and get myself a whopping bill.
