extension15
Distinguished Member
- Feb 13, 2008
- 1,658
- 0
I'll agree to disagree...
Easy one the cow. The vet wears rubber welliesIf a cow munches a high voltage cable, while standing on nice, dry, insulatory(?) hay, while the local vet has his arm up the cows thingumajigs, which one`s going to feel it most?I think SL can be roped in to help with this experiment. All we need is a vet!
Anybody know of one? ]![]()
And this vet wouldn`t get a shock from the potential difference between the inside of the cow, and the outside?????Easy one the cow. The vet wears rubber wellies![]()
the plastic glove between vet and cow would help protect against this!And this vet wouldn`t get a shock from the potential difference between the inside of the cow, and the outside?????
You're 'milking' the cow puns this evening..............Oh moooove over and pull the "Udder" one.![]()
cant we fight? :_| :_| :_| :_|I'll agree to disagree... ]![]()
you woooss!!the plastic glove between vet and cow would help protect against this!![]()
Sounds to be more of whatever YOU happen to be "into" at the time........whatever you're into specs........![]()
Would that be because of introducing a conductive path or have you some other reason ?:|I would consider it safer not to bond..
Or even dangerous to do so.............................
I would cut board to make my life easy :^OUnless he uses screws and, as suggested, marks it up on his cert.I would also cut the board between joists - if i was forced to do it this way - so that the inspector don't have to lift the whole board up to inspect it.
I'm sure you really understand, where I'm coming from binky...Would that be because of introducing a conductive path or have you some other reason ?:| Given how bonding is supposed to work I don't quite see how it makes it more dangerous. But certainly lengths of copper isolated by lengths of Hepco is becoming a greater reality - maybe that's (partly) why we RCD everything now instead of supp bonding ?:| But that sounds sensible so can't be truth :^O :^O
