Is there a specific type of clamp available for the smaller pipes used for oil? I have used a standard Tenby on my oil pipe and it looks as though it will be impossible to route the 10mm earth cable through the cable clamp the angle it sits at means there just won't be a gap... will see if I can upload a photo.
Edit added pic. Lighting is not very good but that lower metal plate in the foreground needs to be used to clamp the cable between it and the upper plate, but there is no room at the back of them as the plate is tight up against the pipe.
Also if I were to tighten that right hand set screw, it would cut right into the oil pipe...
