Main CutOut Fuse vs Consumer Unit Rating
Smarty91
Jan 13, 2023
UK
Hi, not sure if this is the right section as not quite DIY but had the DNO out today to replace the main fuse cut out (the old one had a fused neutral!) they put a 80amp fuse in it before sealing it back up.
I’ve got a new consumer unit to go in which has a 100a DP switch (which I think all consumer units do now?). Am I right in thinking that the consumer unit will be ok as consumer units need to be rated equal or higher than the cut out fuse?
