the thought had crossed my mind]I notice the seal faries havent visited it yet. Maybe after they do you could remove it to see the actual fuse.
gave it ago but all the lights went out so i could not see the fuse:coatI notice the seal faries havent visited it yet. Maybe after they do you could remove it to see the actual fuse.
Maybe a little walk somewhere lighter whilst the fuse is out?gave it ago but all the lights went out so i could not see the fuse:coat
he did have a new digital meter and 25mm tails, would you expect 100a fuse?Generally will be bs88 60 amp thats what I would put down anyway.
Not with fuse holder that age just put 60 amp but not verified.he did have a new digital meter and 25mm tails, would you expect 100a fuse?
While you are completly correct, how do you then isolate supply to replace CU/tails/whatever?I never remove the fuse, sealed or not,just put Not Verified on the cert.
you are not allowed to remove the DNO fuse, that my friend is where you contravene reg 16 of EAW,
unless you are an employee of DNO that is.
you dont. you should get DNO to install isolator, or remove fuse and come back to replace laterWhile you are completly correct, how do you then isolate supply to replace CU/tails/whatever?
Tea with milk and no sugar - on a diet. Ta!Oh no, here we go again.Put the kettle on luv, we could be in for the long haul put the kettle on
