When doing additions or alterations to a single circuit, surely most electricians would be working on one dead circuit whilst the rest of the installation is live? I can't see how testing a single circuit is any different to altering a single circuit, say you extend a radial, do an R1+R2 on the new longer radial whilst its isolated from the rest of the installation. I am unsure what your comment about following regs has to do with this thread? Is there a reg saying we have to isolate a whole installation to carry out any work on that board?Well, it's a 'live' test, sellers - it's not quite the same as doing a 'dead' test with most of the installation left 'live', is it.I've had enough, now, I'm off......... it's been an interesting week.
Ive learnt that it's OK to 'dead test' in a 'live' board, and we only have to follow the 'Regs' that we agree with.![]()
:coat
So why R1 + R2 anyway - if you can't fully isolate - it's a PIR.Was with a chap doing a PIR today all was ok when doing r1+r2 on all circuits bar the lighting circuit,When he did this the main breaker tripped any ideas why this would happen.
All IR readings ok Zs all ok RCD trip times all ok.
To which I got no reply.I think you'll have to explain what you were doing in a bit more detail.
To which I still got no reply.I'm hoping the whole thread is going to make some sense, soon.![]()
Because he hadn't given any reason why it would still be closed (on), during a R1 + R2 test.I'm not getting how the 'main' RCCB is tripping when it should be off anyway.
So it was left on - not for operational reasons, not because the installation couldn't be isolated.....but so they could see.Ok this what the situation was Main RCCB on all circuit breakers in open position i.e OFF, Lighting circuit left on to see what were doing.
Manator,Being able to see, would be one of the most important parts of working around any live connections. The argument comes from the last sentance of your otherwise good post, the first part I can see is fully reasonable, then you spoil it by quoting EAWR as if leaving a lighting circuit on is breaking these regulations.Often there will be fitted a DB socket, the function of this socket?
With modern battery & LED technology you can get some very cheap and bright head mounted torches and small battery powered directional floor standing floodlights. So I would agree alternative methods of lighting a work area should never be a difficulty.There are a multitude of alternative methods of 'lighting' a job - I'm sorry Manator, I can't agree with this.![]()
I'll do my best if i canI think everyones understanding of this thread would be helped if we could have a sketch showing CU layout, which isolators are on/off which circuits are physically disconnected, where any strap links are placed and position of meter probes for test undertaken. Is this possible Bacon?Doc H.
Where did i say the Main RCCB was open?If the Main RCCB was open, how did they have power to the lights? And were these the same lights they were trying to R1+R2?
You were quoted by ADS in #28 although I can not see what he quoted from.Where did i say the Main RCCB was open?
Hi Ian,You were quoted by ADS in #28 although I can not see what he quoted from.
And that is exactly what I said so where did you get that from as he is saying he never said that. Or are you very bad at punctuation and you meant "Main RCCB on, all other circuit breakers open" which is completely different.Hi Ian,The quote says "main RCCB on all circuit breakers open" mate![]()
Thats what i said.Ok this what the situation was Main RCCB on all circuit breakers in open position i.e OFF, Lighting circuit left on to see what were doing.All circuits bar lighting r1+r2 tested IR tested Zs tested RCBO'S tested all fine.All circuits now in open position i.e (OFF) execpt main RCCB.
Get portable light out the van to be able to see what were doing when carrying out the test on lighting circuit carry out r1+r2 on lighting circuit trips main RCCB.
All other tests carried out on lighting circuit all ok IR Zs
I'd like to meet the Spark you has never done any work or testing on a live circuit
