Rather than hijack another thread i thought i would put a few quite boring pictures here.
We had carried out insulation resistance testing on this cable months back, its for one of 3, 3kw immersion heaters in a house. A year later it gets energised & Zs tested. I am imformed by my guy on site that immersion must be faulty as it trips the 16A Rcbo every now & then. Then every couple of days. I was on site all of last week and the Rcbo would not reset. After testing i realised there was a cable fault (95% finished house)
To cut this short i cut the cable where it disappeared into the abyss and was surprised the top end which could be pulled back had the fault. New leg pulled in, jointed, tested & turned on.
I then started cutting the 8m long length of 2.5 Tw&e in half & in half until i had this faulty (L to E) piece of cable in my hand
It looked ok so i sliced open one side
Still looked ok inside
Turned it over, sooty
Had a close look & found this. You can see where something has gone through at about 45 degrees. It scraped the cpc enough to give a rough edge that pierced the brown insulation. The sheath was undamaged though. I pulled the cable in and this part was under a sealed floor. I can only think it was like that before the sheath was extruded at the factory
![imm4.jpg](https://proxy.imagearchive.com/9f3/9f35912a224d003cc1c2448886010991.jpg)
![imm5.jpg](https://proxy.imagearchive.com/b54/b54bf70750982f23042f77643a7d598d.jpg)
![imm6.jpg](https://proxy.imagearchive.com/821/8215f72458b2c3a40082ac0aaf77eb75.jpg)
![imm3.jpg](https://proxy.imagearchive.com/826/826d973a9a86c255c9d64f25bc08d83c.jpg)
![imm1.jpg](https://proxy.imagearchive.com/b7e/b7e899478401eb45645edf783b2f12e2.jpg)
![imm2.jpg](https://proxy.imagearchive.com/bc7/bc7817a4d8d78c6a8ac01bd9dc14636f.jpg)
