MCBs
Continuity test between the in and out terminals, with the MCB switched on.AndyGuinness
That'll blow the fuse in your tester if circuit is live :) make sure it's removed before you do what andy has stated. What is the problem with the mcb?
every time I need to switch the mcb off, when I switch it on again it trips 2 or 3 times before it stays on .... thanks
no it wont. itll only risk blowing the fuse in tester if the breaker is switch off and there is a load connected
What mcb is it?
Curve and rating please?
What is it suppplying?
P.S. WELCOME to the forum!
---------- Post Auto-Merged at 21:07 ---------- Previous post was made at 21:05 ----------
[quote name='Andy
M4tty,
It depends on your meter, I actually did this 4 times today when live fault finding and testing on a control system swapping between V a.c. & ohms on the 110V a.c. control, 240V a.c. & the 400V 3ph a.c. supplies.
However, I was using a Fluke 87 DMM, which is quite well protected against incorrect inputs.
Not sure about the MFT's etc. or any other meter, but, this one survived fine!
AGAIN!!!
The pressure of a production breakdown sometimes takes over.
What load is connected?
Have you tried measuring the load current with a clamp ammeter?
I thought it would blow the fuse sorry ... Just goes to show I've never done it :)
if the MCB is closed, there will be no voltage diference between the probes, so it wont even tell you its a live circuit
if the MCB is open, then it could blow a fuse depending on tester & setting
Mine clicks I think when doing a continuity test on live circuit that's a Megger 1552. It certainly makes you take the probes off quick. Only done it once tho :) but blew a hole in my best cutters yesterday. :(
The MCB is a MEM 16 amps and when tested the load with a clamp meter, the reading was only 9 amps and only lighting, no motors.
Metrel wont let you test is theres voltage present when it shouldnt be. Saved me a few fuses by now i think.
9 Amps of lighting that is quite a load what sort of lighting is it? welcome to the forum by the way.
Welcome to the forum, I am assuming this is some commercial or industrial application. Is there a large bank of lights all coming on together causing inrush current problems. What type of MCB? 'B', 'C', 'D'?
If practicable I would simply swap the MCB for another one (one that is compatible with the DB and with the same rating of course). This could identify the problem very quickly.
