Ive just had my DI assesment and I have not had my meters calibrated for a couple of years.I do however have a home made check box with 0.5ohms, 1.0ohms, 10ohms & 100ohms for resistance checks and 0.5Mohms,1.0Mohms, 10Mohms & 100Mohms for IR checks. I also have a dedicated socket for Zs checks and a plug in RCD to verify my RCD checks. The resistors were just bought from a local radio/tv repair shop and I mounted them in a large IP box with banana sockets.
My inspector was more than happy with my this and we had a discussion about the fact that meters should not really be calibrated on-site due to the fact that calibration should only be carried out in a temperature & humidity controlled environment. Another benefit of doing your own checks is that you are checking monthly, where as if you do an annual cal then if it needs adjustment/repair then you could effectively have 11 months of incorrect readings:O
So long as my check readings remain consistent then I will not be getting my meter calibrated in the next year!
