Met
m4tty
Scaredy cat™
Feb 5, 2009
5,612
reading the green electricians guide to building regs and it says the met has to have a safety electrical connection - do not remove metal tag. Is that correct and does everyone do it?
A sticker is definitely the preferred method on the met as metal tags aren't really designed to be screwed up.
pg 94 brb is your guidence.
dose not matter so long as durable and the right size
Is it ok to use a label printer ie brother p touch or something like that? ThAnks for the replies everyone. Cheers
fine matty. much more pro than pikey isulation tape and marker pen
i've NEVER used the latter method ROTFWL
