The 100A switch in the C/U is the local isolator ..the 80A sw/fuse is fusing & isolating the sub-main .Hi Runner and all those willing to comment and advise.
Though I'm gradually gaining experience having completed a number of installations, I've often found info on this forum useful but until now haven't needed to ask for specific advice.
Along with a full re-wire, a customer wants their C.U. moving to a point under the hall stairs ( approx 10 meters from meter)
I appreciate that the first thing required will be a fused switch e.g. (excel 80a fused double pole main switch) placed close to the meter. (Though wouldn't this 80a fused switch make the 100amp switch in the C.U. irrelevant? can you get a 100amp fused main switch?)
My main question though is, is there a preferred option for running from the fused switch to the C.U.?
(Bulk of the run will be visible in the cellar with approx 1.5 meters needing to hide / be buried as it comes up the hallway wall to the C.U.
Would you advise 25mm SWA ? or 25mm tails (16mm earth) with some steel plate (earthed) protection as they become concealed? or any other options??
The house is a fair size ( 4 Bed ) with TN-S earthing.The current installation already has a similar set-up with an old fused switch next to Meter & 16mm tails run approx 15 meters to the old fuse board in the kitchen. However this was possibly done by the old fella that used to live there, and anyway the regs have moved on since this was installed.
I appreciate all advice and comments.
Thanks Switch Snow
The 17th edition has blessed us with the " Cables buried flush in the walls" business which can cause consternation with sub-mains as no one wants an overall RCD if they can help it.
Lets have a look at the options open to us , some are bordering on madness but things change and we have to go with it .
So depending upon methods of installation .:-
1) 16mm T/E could go with a 63A fuse or an 80A depending on method .
2) 16mm SWA 2 or 3 core ...armour earthed at mains end /flush in wall/ no gland at C/U .
3) 16mm X 3 core Non-Armoured Ins/shd run surface , if flush would need an earthed plate over it or steel conduit
4) 16mm Meter tails @ 63A or clipped direct @ 80A (the flush business applies the same)
5) 25mm Tails @ 100A clipped direct. / boxed in / trunking etc.
6) Run cable surface outside and straight into back of board.
7) Edit :- Forgot Pyro Probably 10mm without looking .
The average 3 bed semi will usually function with a 60A HRC fuse quite happily.
Is there a ruling in the Regs on the size of a steel plate for covering sub-mains ? I don't know ...would some 2mm thick seel plate suffice ..who knows ?
