Alba Albion
Hi, I'm posting these questions on behalf of my Mum in Clacton On Sea, Essex.
At the mo she has micro bore copper tubing through out her 2 bedroom bungalow for central heating. (so has the whole street)
2 main radiators are not heating up, the system is regularly flushed out and well maintained and recently had a new boiler and pump.
British Gas are quoting £3.5k to get, not them, but another contractor to rip it out and replace with 15mm.
Cost is not the issue, unless you good people say otherwise and the job will take a week.
At the mo, this micro bore runs in and out of the walls, down the edge of door frames etc and is very showy.
I think it's ugly but others can live with it.
Our question to you is:
Do you think, when replacing with 15mm it will be on show like the micro bore
or
do you think that the contractors will bury it in the walls ?
What is the normal procedure that you would employ ?
Any advise on this would be appreciated.
Many thanks, Alba Albion.
or
