Turning into quite a common problem and seeing it more and more, I know replacing the Honeywell for a Drayton eliminates the stray 60v as the latter only leaks about 20v...
but my question is...
Rather than replacing, what is the danger of fitting a suppressor between the switch live and neutral to soak up this stray current?
reading up on suppressors they seem to be geared more towards protection from spikes,
this isn’t a spike, it’s a constant 60v that would rise to 200 plus if I was to remove it from the load (swl connection at pcb)
Any ideas?
main concern is how this type of protection fails.. short,open ect...
cheers
jon
Any ideas?
cheers
jon
