Hello.
We have a very old (the instruction manual is dated 2006!) Mira Sport 9.0kw shower.
A while ago it developed a leak which was fixed by replacing the flow valve assembly (including the switch).
However, since then, the shower has failed to heat-up correctly. To get hot water after switching on, instead of it being automatic after a few seconds, we have to turn both the pressure and temperature dials down then up in order for the water to heat. And even then, pressure will seem a little low, plus the low flow warning light will be illuminated.
Taps and toilet flush will have an occasional 'fog horn' sound too. We replaced the ball valve in the loft but this doesn't seem to have had any effect.
It's probably only something minor that needs correcting but it's driving us crazy. Any ideas what could be the problem?
Thanks in advance.
Thanks in advance.
