Derek Preece
- Oct 24, 2010
- 15
- 0
I've been offered a bit of work installing the supply for a 3 phase mortar silo on a building site (I'm not sure if I'm going to do it though, I might pass it on), so I was wondering if anyone could give me a bit of advice.
The supply is 3 phase TN-S though I haven't measured Ze as I haven't been on site yet. It is currently supplying three single phase consumer units- one phase to each from the meter and 3 neutrals from a henley block. My first question is- is it acceptable to use henley blocks to 'tap' into the three phase supply to supply a 3 phase distribution board to supply three phase equipment, without changing anything on the existing installation or should I take the supply to the 3 existing consumer units from the new three phase distribution board and install appropriate breakers. I am trying to think of ways to keep the costs minimal but obviously don't want to do anything that is unsafe.
As the supply is for temp equipment on a building site would a three phase socket outlet incorporating an RCD and appropriate IP rating suffice or does the cable (which is going to be SWA in buried conduit) need to be protected by an RCD at the origin/dist board.
Does the lockable isolator have to isolate the whole installation or just the part that is going to be on the building site (which is the property next door).
Does 10% volt drop apply (I've been struggling to get through to anyone in the company who can answer this due to the christmas period). Thanks in advance
