motor efficiency
searley
Sep 12, 2008
320
help. if a motor`s input is 75w and it`s output is 50w.what will the motor`s efficiency be ?i was trying 75/50 and getting 1.5 but the answer is 33.3%.
see i do need help.cheers. :(
help. if a motor`s input is 75w and it`s output is 50w.what will the motor`s efficiency be ?i was trying 75/50 and getting 1.5 but the answer is 33.3%.see i do need help.cheers. :(
are you sure that is right ,,the answer ???
Apache makes it 66%. If you've managed to make one >100% can you PM me the plans ;)
How exactly is the question worded? Does it ask what the efficiency is OR what is lost.
Apache makes it 66%. If you've managed to make one >100% can you PM me the plans ;) How exactly is the question worded? Does it ask what the efficiency is OR what is lost.
Exactly my thoughts
Power out/Power in = efficiency
Therefore 50/75 = 0.66 recurring (or 66%)
If they are asking for power lost, then it would equate to around 33% (rounding up/down)
i worded it the way it is on the paper i was getting 66%.close to throwing calculater out the window.
