where the wiring of a motor is through flexible conduit connected to earthed trunking the earth connection to the motora - should be via the flexible conduit
b - should be by a separate cable within the flexible conduit
c - should be connected to a bolt on the motor
d - should be connected to the earth terminal
Does anyone know the answer to this ive had a look but havent found answer?
Just a thought for anyone who have to answer from multiple choice questions.
The best way to find the answer if you do not know it off the top of your head and lets face it we are electricians not doctors is to eliminate the unlikely.
From the above example lets take each answer choice one by one.
A, should be via the flexible conduit.
If flexable conduit is used we can assume there is going to be a vibration problem with the use of the motor, the flexible conduit whilst able to take the normal strains of vibration has weak points along its length that can be damaged, or even seperated.
Not likely to be relied upon for safe earthing.
B, Should be seperate cable within the flexible conduit.
If the flexible conduit for the reasons stated could not be relied upon for safe earthing then a seperate cable within the conduit would be a good solution.
C, Should be connected to a bolt on the motor.
We have already established that there is some vibration associated with the motor, so a bolt is unlikely, also which bolt? not likely to be a single bolt on a motor that has an earth symbol on it.
D, should be connected to the earth terminal.
Now then, now then, every earth cable must be connected to the earth terminal. This is where reading the question comes to the fore!
Its not asking the obvious we all know it should be connected to the earth terminal every earth should! Its asking about the method of supply to the connection, otherwise why mention the flexible conduit, or the earthed trunking?
By eliminating the obvious I would in this instance say that the answer is
B
Unless you have some sad lecturer who says its
D
In which case tell him all earthing is to an earth terminal
