Stresbringer
Hi eveyone
I am pretty new to these forums but I was hoping that someone was willing to help me.
I have a motor which I need to wire up to a normal 3 pronged plug, however I am not 100% sure where each of the 3 wires go and to which terminals.
the pictures are below
The terminals I have are as follows
Terminals:
S ------> No wires connected
P ------> No Wires connected
R ------> No Wires connected
U1 ------> Black & Yellow connected
U2 ------> Red & Red/Green striped connected
Z2 ------> Blue & Red/Green stripped connected
I just need to check to see were the Live, neutral & Earth go, I've looked at the wiring diagram above and I assume that the neutral go to U2 as labelled and I think HP HR LINE must be the live however I have no idea where to put the earth......
if it helps the motor if from an frying range extractor fan. and I plan to use it and replace the motor on my homemade bench sander
Any help would be very much appreciated
Thanks in advance
Stresbringer
![d0e7f776-89d2-480b-b802-fdc73b0bd9f3_zps680025d2.jpg](https://proxy.imagearchive.com/fba/fba631cd8bfe640919130cbe9ef5565b.jpg)
![IMG_0018_zps1a694988.jpg](https://proxy.imagearchive.com/3b4/3b480e84cda0140210d3c5577ccc917c.jpg)
Terminals:
Thanks in advance
Stresbringer
