One for Steps here!!
I stripped my villiers bike engine, and had a look at the crank and there was about 3 thou radial play in the big end. On the one hand i thought it was not a formula one car, but on the other you could very clearly hear the "knock" echo through the cases as you worked the "slack" up and down, so with the motor running, i can only assume it would have been fairly horrendous. It would not get any better either and i could do without the motor throwing a rod.
Am i thinking along the right lines or being too fussy??
john..
john..
