Same here...I used to use that feature but realised it was a bit useless for historical records as every time you opened the document it would overwrite the date with todays date so I never knew what the date of the invoices was. Not sure of that was using the Insert > Date feature or something else similar, it was a while ago and I haven't use Office for years..
Thouyght there would have been a simple way of turn it on or off once the document was opened. Tried the F11 options, but doesn't seem to workI used to use that feature but realised it was a bit useless for historical records as every time you opened the document it would overwrite the date with todays date so I never knew what the date of the invoices was. Not sure of that was using the Insert > Date feature or something else similar, it was a while ago and I haven't use Office for years..
