Msc certificate
Lydanial
Aug 20, 2023
12
2
Hi all,
Had my installation a week ago and received paperwork today.
My system
14 420 trina panels
9.5kw givenergy battery
5kw givenergy inverter
My msc certificate has a line in it,
Declared net capacity 3.6
My system is supposed to be 5kw with the g99 although I haven't received a 98 or 99.
Do you think they're applying for a g98 while the g99 goes through and will then issue a follow up certificate?
Unsure how this bit of the prices works to be honest.
net export, I would assume it has 16A export limitation. You won't get the G99, that goes to the DNO although you should get a notiifcation from them that they have accepted the installation.
It's supposed to be 5kw inverter and from looking at my givenergy app I've had peak exports around 5kw...
I'm actually concerned they haven't applied as it's been reading and seeing information that says they spoils apply and get permission before the installation.
I have made another thread regarding this as I think they've made a false declaration and stitched me up a bit.
