Multiple light fitting with LEDs
Owd Oss
Mar 22, 2016
Northumberland
I have a light fitting which takes 10 x 10w, 12v G4 bulbs and have recently changed to 1.5w LED bulbs but they are very dim. If I replace 1 LED bulb with a halogen bulb they all light to full brightness!! Any ideas how to overcome this please? The bulbs are cool white and I can't find a cool white halogen so this is not a good solution.
Many thanks
As previous poster probably not enough to load. You could either increase the wattage of the bulbs (lamps) or change the transformer in the fitting with a lower min wattage rating.
What about a capload across the output terminals?
I doubt that would help, a resistive load would be more likely to cure the problem (as can be demonstrated by adding a single halogen lamp)
LED lamps are already presenting a capacitive load to the transformer so increasing that capacitive load won't help, adding a small resistive load does help.
